6
Everything posted by Harbinger
I hear that. The one thing I miss from my 87 two door is the working dash. So may try and do a custome gauge cluster with the standard oil pressure, coolant temp, voltmeter, tach, speedo, odo, fuel etc. Then might save the gauge pod for more not so standard items.
Pre Cut window tint... Has anyone tried it?
Harbinger replied to JohnMasters's topic in 90-95 WD21 Pathfinders
Fixed that for ya! I'm curious to see how these projects turn out for you guys. I have a hard enough time applying a sticker without air bubbles. I just had a shop do mine. -
Harbinger's Automatic to Manual transmission swap.
Harbinger replied to Harbinger's topic in 90-95 WD21 Pathfinders
I tried that yesterday, but perhaps soaking overnight in PB blaster will change things. If I can cure this hangover ill go back out and give it another go. -
I am aware they are splined. Rubber mallets, pulling, hosing them down with PB blaster, etc hasn't removed them from the front mounts. They came out of the rear mounts fairly easily... Checking the FSM they have you remove the torque arm with the bar, thus why I'm fighting with those bolts on the LCA. Could care less about maintaining their position, although I did mark both sides of each bar. Will probably be replacing the t bars with new stiffer units when I reassemble. -
What can I say, I do like holes! Most of them anyway, now that I've ordered a pillar gauge pod, and decided to convert to a 5 speed, I'm kinda regretting drilling that 2"ish hold in the lower dash panel for the transmission temp gauge. The very same gauge I need to rip out now... Thanks dowser, I've been doing so much searching that I thought I would condense things here. I'm a professional photographer (at least when I'm not spouting that I'm a student or an unemployed layabout!) by trade so it made sense to post some things here. All photos are hosted by image shack, so hopefully the links will last... Made some progress today on the t-bars. I'm currently stuck trying to remove them from the LCA's. All the adjusters, the C clips etc have been removed. I've loosened all 3 bolts that connect them to the torque arms, but the largest of 3 bolts is proving difficult. The 19mm bolt is just spinning, and I can't for the life of me get a wrench, or socket into the LCA to stop it from spinning. I also pulled the bolts for the t-bar xmember, but the x-member is still stuck to the frame. I left everything soaking in PB blaster before packing up my tools. My main point of reference for tackling the t-bars was this thread: http://www.nissanpat...r-torsion-bars/ The part that isn't included in that thread is actually removing the bars. Through my searching I found a few people commenting they had to loosen the 3 bolts holding the t-bar to the LCA to remove them. Which is where I'm left for the day. I will try to get back out to the truck tomorrow, and post some pictures. -
How the hell am I supposed to get a wrench on the large torque arm bolt? The 19mm one where the t-bar meets the LCA.
87 twin turbo sas 1 inch lift...
Harbinger replied to AK9849cy's topic in Solid Axle Swaps, Hardcore Custom Fab
Beautiful work! You sir are indeed a god among men. Here I am being baffled by a transmission swap, let alone doing custom fab work! -
I had a similar experience a few weeks ago. Certainly not the same cause though! (Filter was plumbed backward). I was able to limp home around 35-40mph when mine blew. This was with my hazards on in a 75.... I only had about 20 miles to cover and I felt very relieved when she got me home. Once there I didn't trust it running to the store, let alone 200 more miles...
I didn't either at first. When I installed a battery in the rear of my truck and installed my. Aux lights, thants where I brought the cables through the firewall. Had no idea at the time that id be converting to a 5 spd! -
Que? The wiring I'm currently "re-wiring" was all aux stuff ran through the hole where the clutch master cylinder installs. I will jumper the transmission lock when the new tranny is in lol. How do you mean "through the panel"? I know where that one I pictured comes out, but I figured with enough wire wrap and e-tape you can insulate about anything. I am open to other suggestions though. So far I don't have any of the MT parts. I'm waiting on my student loan refund to find a suitable donor truck to strip down. -
I like the way you think.
I'm sure most of you know that my Autotragic transmission died on me a few weeks ago. Details are here: http://www.nissanpat...how-boned-am-i/ I've decided to swap in a 5 speed. I'm referencing a few threads that are helping me out a lot. I'm putting them here just to aid searching in the future. I abused the hell out of the search button before starting this, and have gone through quite a few engine/transmission removal threads too that I won't mention here. http://www.nissanpat.../page__hl__swap http://www.nissan4wh...25218489/page/1 So it begins: Yesterday I started at the top of the truck. I removed the center console, several dash pieces, the AT shifter, and the shift-lock cable. Today I was able to remove the steering column. I hadn't been able to remove it because the slip joint near the firewall was corroded. I unbolted the bracket (2 bolts) that held the end of the secondary steering column to the steering column and was able to pull it out. Once the column was pulled I removed the AT specific brake lever. I'll need to source a shorter one to go with a clutch pedal/bracket. Once the top was done (well for the moment) I moved under the truck. I removed the front and rear drive lines (or propeller shafts per the FSM). I then disconnected the AT shift cable from the transmission. I'm fighting with the electrical connections, these factory plugs can be difficult to disconnect! I hosed down some cross member/t-bar/exhaust bolts with PB blaster. Then packed up my tools and started drinking beer. Side note, can anyone tell me what this plug was meant to have? It sits just up and to the right of the gas pedal. I had to remove my battery cable that runs to the rear of the truck, and all the relay wires for my aux lights since I ran them through the Clutch Master cylinder plug before! If it isn't anything I'm going to need in the next few weeks, I'd like to rewire my cab->firewall transition there.
I finally got the steering column and AT brake lever out today! Also pulled the drive lines and disconnected the AT shift cables. Hosed down the rest with PB blaster and packed up for the night. Tomorrow, I hope to remove the t-bars and part of the exhaust.
Pulled out the center console and the lower drivers dash pieces. Removed the AT shifter, shift lock cable, and unbolted all the bolts on the brake pedal and steering column. Also removed the wiring I had ran through the plug where the future Clutch Master cylinder is going to go. Will reroute the power and light wires later after I'm sure of where everything is going to go. I'm currently stuck removing the steering column. I have all the bolts removed that I could find, and all the wire harness plugs disconnected (and double checked against the FSM), but it doesn't want to pull out. Thinking it's corroded @ the slip joint in the engine bay. Soaked it down with PB blaster and gave it a few raps with a mallet, but no dice. I'll try again tomorrow on that steering column, but now, it is time for a shower, then a motorcycle ride for dinner and beer.
Successful install of MSD coil 8228 No mess no fuss :)
Harbinger replied to gv280z's topic in 90-95 WD21 Pathfinders
Interesting that you bring up LIPO and brushless motors. My recumbent trike uses both those things! -
That's a big part of the plan that I want too. Enough solar and wind power to charge a battery array that will in turn power the essentials while funneling power back into the grid. I'm just too broke right now, and renting my current house. Will find my career path as a welder/machinist and live my dream! -
I want to upgrade the ignition on my my truck too. However I'm stuck waiting for a new transmission now. Probably going to convert my rig to a stick shift. I really haven't gotten the chance to try out the Geolanders or the Soft 8's yet. They were on for all of 80 miles before the transmission filter I plumbed fried it. The plumbing has been fixed but am waiting on the new tranny to be installed. You win some and you lose some! I also conur, B is ahead of the exploration/shiat hits the fan vehicle for sure! Hell, I'm still dreaming of installing a 2" body lift! -
Today I bought some new jack stands. Got them home and jacked up all four corners of the truck. Going to go back out and do another premptive pb blaster run. Tomorrow, I begin the transmission pull.
Screw the naysayers. We like irrelevant upgrades here! -
WTF! A PINK PATHFINDER. (Got what it deserved)
Harbinger replied to ferrariowner123's topic in Off-Topic
I saw this topic and thought "What has Nunya done now?". -
Today I crawled underneath the truck and hosed down tranny x-member, exhaust and drive shaft bolts with PB blaster. Not sure when I'll be attacking those head on, but a little PB never hurt before.
Put her in neutral and pushed her backwards into my driveway.
Mine was missing several when I removed the grill a few weeks ago I just bolted it on with some short machine screws, nuts and washers.
