4
Everything posted by vengeful
I've got the front completely off and the rear has bad links (so it doesn't do much good), on my 99. I did notice a slight increase in body roll during panic maneuvers, but it is not to the point where I wouldn't feel comfortable driving the truck 75mph on the interstate. At one point, I had taken the rear completely off, and the body roll increased a little bit. It wasn't to the point where I was scared, but it would definitely have taken some getting used to, and I wasn't used to it after a couple of days, so I put it back on. (This was before the links went bad...currently the body roll is about halfway between where it was with good links and where it was without the sway on at all...right where I like it!). I must say though, without the swaybars, the truck rides a lot smoother, and bumpsteer was reduced dramatically. I also get a lot more articulation out of the front. I know what you're thinking..."Front flex on a Nissan? Go on!!"...but I'm serious, I can max out the compression on one side and the droop on the other. Before, with the sway in place, I could only get about 2-3" of independent travel, now I get full articulation...it's WONDERFUL...ALSO, my struts don't seem to top out as much without the swaybar as they did with it... So...if anyone wants a swaybar for an R50, I've got one sitting in my garage collecting dust...and it will continue to collect dust forever...hehe.
I've been seeing a pretty consistent 16mpg recently. That generally equates to about 230-240 miles before the "idiot light" starts to flicker on downhill grades at red lights. (At that point, the truck will take 16.5-17 gallons, I have a 21.3 gallon tank according to my manual, but I've never managed to get more than 19.4 in it...).
Congrats... I've already noticed some changes for the better going on...keep it up Aaron!
Kris, You suck at Photoshop...at least make the lighting the same on the both of you... :X
Anyone? Anyone? Beuller? Beuller? :help:
+1 Hmm...I'm gonna have to say Jessica Alba or Angelina Jolie...
Does anyone happen to know the length, diameter and thread pitch of the step rail bolts? TIA.
So you want to lift your 96-up Pathy?
vengeful replied to BigBikeMike's topic in R50 FAQ's & Pinned Topics
You actually want to lock them before you engage 4wd inside the cabin. At least that's the way I've been doing it for 2 years...if it ain't broke, don't fix it, right? -
The Surco racks are garbage. They are aluminum, and simply cannot withstand very much weight in them. Since you have a MIG Welder, you might want to consider getting some 1" steel square stock and fabbing your own.
When I moved back up to school last fall, I had a Uhaul 6x12 trailer fully loaded, and my Pathy full loaded to the ceiling, and stuff on the roof, and my bikes off the back. Out of curiosity, I stopped at a scalehouse, and I tipped the scales at 10,280 lbs. And my little VG33 managed to get me there without a problem. Didn't overheat or anything. I am more and more impressed with my truck every single day, and I've had it for 3 years and 65,000 miles!
They replace the full time drive flanges that exist on your truck. They work by turning the "face" of it to lock in the hub. When the hubs are locked, it is basically like running as stock, but you can opt to unlock them to disengage the front drivetrain. -
I say go for it, but be aware of a few things that will arise from lifting it. These are in regards to the 2" (advertised) lift (I got 3"F and 3.5"R): Firstly, your front struts WILL top out going over bumps. This WILL NOT cause any significant problems, it is more of an annoyance than anything. But it will scare the living crap out of you the first time it happens, and you'll turn around and go right back to the shop and be like WTF! :confused: I've had my lift on for 50,000 miles, and the struts are just now starting to feel like they're wearing out. I'll likely have to replace them in about 10,000 miles...KYB's estimated useful life for them is ~60,000 miles anyways. I think that I've gotten a great amount of life out of them considering how and where I drive my truck. Secondly, your CV axles will be at a more extreme angle, and this will expedite the wear on the boots. To alleviate this, I HIGHLY suggest getting the Warn Manual locking hubs to replace your full time drive flanges. With the warn hubs unlocked, and the t-case in 2wd, you have the entire front driveline disengaged, and nothing is turning. This in turn creates less wear on the front end driveline parts, and will give you a slight increase in fuel economy. (I saw about a 1.5-2mpg increase). I did not install the manual hubs immediately, and regret not doing so, because I had to replace both CV axles at the same time, to the tune of $200. Thirdly, since the 2" AC coils are not any longer than the factory coils, but are simply a higher spring rate, the ride of your truck will change completely. I love the way my truck rides now. Before I lifted it, it felt like a station wagon, now it feels like a truck should. It will ride stiffer, and the suspension will be a lot firmer. Stock, you can fit 31x10.50" tires on your factory rims. With the lift, I had no problems fitting 32x11.50x15" tires on 15x8" rims with 3.75" Backspacing. In order to fit 32s, you MUST get new wheels with a backspacing of no more than 4", otherwise, the tires will not clear the strut. Finally, nothing can be better than the looks you get driving a newer Lifted Pathfinder with big mud-tires...I LOVE IT! I say DOO EET!!! -
Nissan recommends 3 7/8 with filter change, and 3 3/8 without. I usually just put in 3 3/4, close enough for government work, and the truck seems happy with it.
You absolutely DO NOT want to use alcohol to clean it prior to applying Herculiner. The Herculiner will not bond to the surface after it has been cleaned with a product containing ammonia or alcohol. They recommend using Xylene, but Acetone works as well.
Yeah, Coal Creek was a hell of a way to celebrate....I didn't have any porcelain gods to look on me at all, so, it ended just fine!....I didn't touch Nate's Tequila.....*cough* Ryan *cough*....
They said it couldn't be done... TJM Bumper
vengeful replied to Pezzy's topic in 96-2004 R50 Pathfinders
I hate you so much.... -
Other than the different motors, the only difference between the two is they changed the geometry of the rear suspension to allow the shocks to be directly vertical, instead of at a slight angle. If you're looking at a 1999, instead of a 1999.5 (newer body style (same as the 2001), then there are quite a few differences, however they are all cosmetic. Some newer models have a knob for the 4wd instead of a lever. Between the two vehicles, there isn't really a distinct advantage to go with the newer one except for the engine. I'd probably go with the 99 due to the price. Also, I'm a little biased cuz I have a 99...haha.
I've decided that I want to coat part of my truck, and I'm debating between Line-X and Rhino Liner. Has anyone had Line-X applied? How much did it cost? Same for Rhino Liner. What are the differences, besides being spray on and roll on. Etc....
I just ordered a set of those. I'll let you guys know in a couple weeks...
I personally like the Brakleen Flame Thrower to eliminate wasps.....
At least now you'll remember to double check them before you go out in the future...
Flyer, I have the BlackPanther skids, and they are amazing. The craftsmanship on them is superb. They're very easy to install...with 5 arms or a jack/cooler to support the plate. One thing, just make sure you get the rear most bracket bar on the right way, or the holes wont line up. I've got the smaller one, and they've held up to everything I've thrown them at, including a big rock at 10+mph that stopped me dead in my tracks with not so much as a little knick in the powdercoating. For the price, and the level of support that Marcel offers, you really can't go wrong.
More reason to mount the hi-lift on the truck....they make for good clubs....hehehe.... I'm 21 and my sister is 15, she's scared to go to any of her high schools sports events because of the stupid crap people pull there. I went with her to one and got in a big hiney fight. Why do YDFOC kids try to start (I am a dork for trying to use profanity here) with people who have 80+ lbs on them and 4-5 years on them? Granted, I'm not the biggest guy in the world, but at 6' 220 and built like a linebacker, most people wont mess with me, but there are those few dumbasses that just dont know whats good for them.
You can't go wrong with a Nissan, even a first year. Their warranty service has been excellent in my experience. As for your first gripe, there is already lots of aftermarket development for the new Frontiers and Xterras. You should start seeing parts available in the coming months.
I've camped in the back of my Pathy before, but only for a couple days at most. Never spent an extended period in there....
