Coucoui6 Posted April 20, 2008 Share Posted April 20, 2008 okay i just installed 1/2" spacer btw the upper control arm and the ball joint? so i reindex it? but i also added a few clicks clockwise for the passenger side and counter clockwise for the driver side. did i do it right? i just seems like i have the t bar cranked pretty high to get the lift? i cranked the t bars before i added the spacer but it just seems like should have more adjustments since the spacers are in. thanks, coucoui 6 Link to comment Share on other sites More sharing options...
Coucoui6 Posted April 20, 2008 Author Share Posted April 20, 2008 i think i just figure it out. thanks. Link to comment Share on other sites More sharing options...
MY1PATH Posted April 20, 2008 Share Posted April 20, 2008 installing a spacer under your UCA ball joint will help correct your lifted camber as well as allow a little more downtravel. I don't think It will change your ride height or T-bar Ajustment (unless your trying to get more lift out of it w/o hitting the uca bumpstop) where did you get your UCA ball joint spacer btw? Link to comment Share on other sites More sharing options...
Coucoui6 Posted April 20, 2008 Author Share Posted April 20, 2008 installing a spacer under your UCA ball joint will help correct your lifted camber as well as allow a little more downtravel. I don't think It will change your ride height or T-bar Ajustment (unless your trying to get more lift out of it w/o hitting the uca bumpstop) where did you get your UCA ball joint spacer btw? i got it from 4x4 parts.com. it was cheap... Link to comment Share on other sites More sharing options...
Simon Posted April 20, 2008 Share Posted April 20, 2008 Careful about wheeling with those on. THere are pics around here somewhere showing the damage to stock UCA's with spacers in. Link to comment Share on other sites More sharing options...
88pathoffroad Posted April 20, 2008 Share Posted April 20, 2008 Ball joint spacers can damage stock UCA's. They are bad. http://www.nissanpathfinders.net/forum/index.php?showtopic=2598 Link to comment Share on other sites More sharing options...
GrimGreg Posted April 21, 2008 Share Posted April 21, 2008 (edited) Ball joint spacers can damage stock UCA's. They are bad. http://www.nissanpathfinders.net/forum/index.php?showtopic=2598 Just the larger, 1" ones right? I've never seen or heard complaints on their 1/2" ones. Edited April 21, 2008 by GrimGreg Link to comment Share on other sites More sharing options...
Coucoui6 Posted April 21, 2008 Author Share Posted April 21, 2008 Ball joint spacers can damage stock UCA's. They are bad. http://www.nissanpathfinders.net/forum/index.php?showtopic=2598 wow, i just read that tread and it is pretty bad. i hope that dont happen to me! i only have the 1/2" spacers on mine for a few weeks. Link to comment Share on other sites More sharing options...
