WiredWrong Posted June 6, 2012 Share Posted June 6, 2012 Does anyone know where I can find this book or the pdf. file ? I'm doing massive rewiring of my whole system and i don't feel like playing burn my truck down cause I wired something wrong (<---lol's at user name) Link to comment Share on other sites More sharing options...
nunya Posted June 6, 2012 Share Posted June 6, 2012 http://www.nicoclub.com/FSM/pathfinder/1994_Pathfinder/ its for a 94 but should be at least somewhat helpful depending on the system your planning on messing with as a little help (the "el.pdf" selection is the electrical section). Otherwise my 88 FSM is proably about useless to you for me to look anything up Link to comment Share on other sites More sharing options...
DantheMayun Posted June 6, 2012 Share Posted June 6, 2012 (edited) http://www.nicoclub....994_Pathfinder/ its for a 94 but should be at least somewhat helpful depending on the system your planning on messing with as a little help (the "el.pdf" selection is the electrical section). Otherwise my 88 FSM is proably about useless to you for me to look anything up Wow talk about lucky. I finished my lift and i'm having some electrical problems! Hehe fun fun fun... So far only found a broken wire behind horn on firewall... Hopefully thats it!!! Edited June 7, 2012 by RedPath88 Removed Duplicate Quotes Link to comment Share on other sites More sharing options...
WiredWrong Posted June 6, 2012 Author Share Posted June 6, 2012 I just got done rewiring the "lighting switch/ASCD set switch, the wiper and washer switch"; (aka combination switch) moved them off the steering column, now i've got a parasitic drain somewhere from point A to point B. Think it might be in the cruise control wiring; might just remove the whole cruise control system, never use it anyrate. Going to relocate the whole ignition cylinder system later on in the week so this helps alot nunya Link to comment Share on other sites More sharing options...
