Hytekrednek Posted November 18, 2013 Share Posted November 18, 2013 This is most likely somewhere else in here but I just felt I needed to ask. When I first start my 93 Pathy the lights, HVAC fans and pretty much all electrical seems to be going slow. Then after a couple of minutes it's like it kicks into high gear for the electrical. No CEL, no idiot lights. It only seems to do this if it sits overnight or after the vehicle has completely cooled down. Has anyone seen this on there ride??? I have yet to do an alternator update on my rig. James Link to comment Share on other sites More sharing options...
nunya Posted November 18, 2013 Share Posted November 18, 2013 Is start with a check of the alty AND the battery, make sure you ain't starting up on low juice and getting good charge. Link to comment Share on other sites More sharing options...
Hytekrednek Posted November 18, 2013 Author Share Posted November 18, 2013 I know that it is a good battery. And as strange as it seems is it is charging at a good rate as well. I'm hoping that when I do an alt upgrade that it will fix the problem. Link to comment Share on other sites More sharing options...
RedPath88 Posted November 18, 2013 Share Posted November 18, 2013 (edited) How do you know the battery is good? Hopefully not just because it is xx months old, because I just had a 6mo old battery die on me (along with the alty, which one could have killed the other.) Edited November 18, 2013 by RedPath88 Link to comment Share on other sites More sharing options...
RedPath88 Posted November 18, 2013 Share Posted November 18, 2013 Oh and I would recommend that you figure out exactly what the problem is before you put a new alty in. I'd suggest that you pull both and have them tested independently. Link to comment Share on other sites More sharing options...
Hytekrednek Posted November 18, 2013 Author Share Posted November 18, 2013 I had the battery tested recently when I forgot to turn off the dome light and killed the battery. Took it in and had it checked before it was charged and put back in the truck. Will have the alternator checked this week. Link to comment Share on other sites More sharing options...
vagabond Posted November 18, 2013 Share Posted November 18, 2013 you may also have a draw on the system, drawing the battery down Link to comment Share on other sites More sharing options...
Hytekrednek Posted November 19, 2013 Author Share Posted November 19, 2013 Well the dome light was the draw that caused the initial reason for checking the battery. So I will have the alternator checked this week to see what I can figure out. James Link to comment Share on other sites More sharing options...
Precise1 Posted November 19, 2013 Share Posted November 19, 2013 A quick, easy thing to check is the connections, terminals, clamps, wires, ground points, alty connections, etc. Sounds like something is heating up and engaging better... B Link to comment Share on other sites More sharing options...
Hytekrednek Posted November 20, 2013 Author Share Posted November 20, 2013 Thanks for that insight B. Will be checking it out to see if there are any loose connections at the alternator. Thanks for all the help. James Link to comment Share on other sites More sharing options...
vagabond Posted November 24, 2013 Share Posted November 24, 2013 Just for the heck of it if you have a volt ohm meter, check the battery voltage in the morning before starting, then check and see what it is after the engine is running for a few Link to comment Share on other sites More sharing options...
