mdwarren289 Posted May 30, 2016 Share Posted May 30, 2016 I recently had a no start after shut down. replaced the distributer thanks to suggestions here. Worked great. Had it out on the beach yesterday, nothing too aggressive, but it just shut down. Luckily I got it towed away from the incoming tide, then got my truck and towed it home. Still can't get it to start. It has spark and I can smell fuel. Has anyone had a similar issue? Starter cranks engine so I don't think it is catastrophic. Link to comment Share on other sites More sharing options...
Rebelord Posted May 30, 2016 Share Posted May 30, 2016 Check fuses and relays Sent from my SM-G920V using Tapatalk 1 Link to comment Share on other sites More sharing options...
rc_cola_j Posted May 30, 2016 Share Posted May 30, 2016 (edited) I had a similar issue last fall. Shut-down and wouldn't start......replaced the distributor. Worked great for a week then it died again and had a no start issue. Turned out to be a faulty camshaft position sensor. Can you see if the ECU is showing any codes? Sent from my iPhone using Tapatalk Edited May 30, 2016 by rc_cola_j Link to comment Share on other sites More sharing options...
mdwarren289 Posted May 30, 2016 Author Share Posted May 30, 2016 RC Cola - My rig is a Canadian model also so I will definitely check the sensor. I haven't gotten a code reader on it yet, but that is next. I'll get back to you on that front. Thank you for the help. 1 Link to comment Share on other sites More sharing options...
