MaximumHP Posted June 24, 2006 Share Posted June 24, 2006 I'm trying to figure out why my brakes have been squealing lately and trying to get the rear caliper off, but can't figure out how to detach the top of the caliper. There is no bolt, just the pin as shown in the pic. BTW, I think this is the problem since I can barely move the caliper and it doesn't slide in and out like I'm guessing it's suppose to. How do I get this off to remove the caliper? Link to comment Share on other sites More sharing options...
GrimGreg Posted June 24, 2006 Share Posted June 24, 2006 There should be a bolt through the top too. Is the head of it sheared off? Link to comment Share on other sites More sharing options...
MaximumHP Posted June 24, 2006 Author Share Posted June 24, 2006 (edited) No, there is like a stainless cap on the end. All the manuals I have say "take the two bolts out" that's why I don't know how this pin works. It's the rear caliper on a 91 if that makes any difference. Edited June 24, 2006 by MaximumHP Link to comment Share on other sites More sharing options...
GrimGreg Posted June 24, 2006 Share Posted June 24, 2006 All my manuals show a 2 bolt setup also. Can you service it by just rotating the caliper up and back on that pin? Link to comment Share on other sites More sharing options...
MaximumHP Posted June 24, 2006 Author Share Posted June 24, 2006 Not sure, it doesn't want to move along the axis of the pin which is probably the problem. I tried a hammer and it didn't budge. It's starting to rain, so I may have to revisit this problem another day. Link to comment Share on other sites More sharing options...
sammyb33 Posted June 24, 2006 Share Posted June 24, 2006 are you sure its a pin, and not just a horribly rouned out bolt head?? possibly by the previous owner...??? Link to comment Share on other sites More sharing options...
MaximumHP Posted June 24, 2006 Author Share Posted June 24, 2006 Positive. If I could get a better pic I would. It's like a stainless steel cap with a little rubber cap on the end where you might put a grease zerk or something. I tried to get the cap off to see if there was a bolt underneath, but it aint coming off without destroying it. Both sides are exactly the same. Apparently if it came this way stock it's fairly uncommon Link to comment Share on other sites More sharing options...
sammyb33 Posted June 24, 2006 Share Posted June 24, 2006 hmmm...u have a 91 right.... cuz i was gonna go out and look on my truck...but i have a 95.....hmmm still gonna go look... Link to comment Share on other sites More sharing options...
Maz Posted June 25, 2006 Share Posted June 25, 2006 you could remove it by removing the two bracket bolts that mount it to the backing plate?? THen buy a new caliper that comes with the bracket (semiloaded). That's how I replaced mine hope it helps Jamie Link to comment Share on other sites More sharing options...
govols74n Posted June 28, 2006 Share Posted June 28, 2006 mine was the same way, put a strong screwdriver between the bottom of the calliper and the rotor, pry away.....its just stiff and it will ( the bottom) slide up...once you break it loose it will be fine. Link to comment Share on other sites More sharing options...
Guest pughster Posted July 4, 2006 Share Posted July 4, 2006 yeah i just finished working on the brakes of my newly purchased 94 se. the rear brakes are the same as you describe, just take out the lower bolt- with the head on it, then i used a hammer to swing the caliper up and off the pads. Link to comment Share on other sites More sharing options...
Vividkid Posted February 5, 2013 Share Posted February 5, 2013 Theres no allen head inside the end of the bolt? Link to comment Share on other sites More sharing options...
pathybuilder Posted February 5, 2013 Share Posted February 5, 2013 LOL, almost replied to this, just realized it's 7 years old. Link to comment Share on other sites More sharing options...
Precise1 Posted February 5, 2013 Share Posted February 5, 2013 I guess they are still waiting for an answer? B Link to comment Share on other sites More sharing options...
